Heard awesome things about your work BJ. For the last 4 months AAEN has had my enigne.. To say the least..Next year you will be the call I make for work!
I meant internals, I plan a tear down after the season and planned to look into some mods to the motor while it's tore down.
I was thinking BB but maybe just some porting??? Who knows.
I blew up my primary last weekend and I was wondering if this is common with the TRA 3 clutch? What should I replace it with? Its an 04 summit. Thanks
Hey BJ. I am having some electrical issues. I ride a '03.5 Summit. My tach, stopped working, I have three lights on on my dash, the headlights are dim, and I am very low on power. There is only about 6V running out of the regulator. I have replaced the regulator, and still no luck.
1) Where is the ground strap on these motors
2) Would these symptoms happen if the stator was having issues (resistance tests all passed)
3) Other than a shorted wire (which I haven't been able to find yet) or a dirty/loose ground (which I can't find either) do you have any idea what would cause this?
Thanks for your time
