a fella after a while knows your in the "ballpark" with out a torque wrench..but you have to work around the mechanical trade quite a bit
Replace all your head bolts now and check all the threads in the Cylinders. (fixed).. Not just the ones you broke but ALL of them.
Use factory bolts and a correct sized torque wrench as said above.
put some grease on the underside of bolt head and a smidge on the threads
Agreed. The 'ol calibrated wrist or elbow, as the case may be.
In my past life I had a drawer full of preset torque wrenches and drivers that ranged from in/oz to ft/lbs.
Having done it about 50 or 60 thousand times over 20 years I'm confident I'll be able to tighten a panhead screw to 4-6 in/lbs until they put me in the box.
Making Sure there is not Anti-Freeze in the Bolt Holes! This causing it to hydo lock and strip a thread.. FYI!
The Head Bolts Thread in to the Cylinder! Go Through the Head! fyi!
Whenever I hear these stories (breaking head bolts with low torque) it almost ALWAYS gets traced back to this because the novice pulls the stock head off before draining the coolant all the way down. I'd bet my paycheck that's what happened. Make darn sure those bolt holes are free from coolant!!!
Have FUN!
G MAN
Have FUN!
G MAN
Have FUN!
G MAN
WRONG. I will send you my address for that check. I hope it's big.![]()
