R
Ratchit
ACCOUNT CLOSED
Below are the numbers closest to160Hp for the 3 dyno runs done back to back with pipe/muffler temps increasing for each run.
MAX Power Engine RPM changes very little by only 50 rpm.
MAX Power drop changes very little by only 1.4 Hp.
@ 8100 rpm (blue lines). As the pipe/muffler temps increase for each run it causes the engine management to run richer in fuel for a safer running engine.
The Polaris Powertrain engineering team appear to have done an awesome job in Engine Management to bring consistency to a high strung two stroke.
1st run
7750 160.8
7800 162.1
7900 164.6
8000 166.6
8100 167.6 Hp 12.84 a/f 258 scfm 93.5 lbs/hr 0.562 BSFC
8200 167.1
8300 164.7
8350 162.2
2nd run
7850 160.9
7900 162.2
8000 164.8
8100 166.8 Hp 12.45 a/f 253 scfm 94.9 lbs/hr 0.573 BSFC
8150 167.3 Hp 12.39 a/f 255 scfm 96.0 lbs/hr 0.579 BSFC
8200 167.2
8300 165.1
8400 160.9
3rd run
7900 160.7
8000 164.3
8100 166.0 Hp 12.29 a/f 253 scfm 96.0 lbs/hr 0.583 BSFC
8150 166.2 Hp 12.21 a/f 253 scfm 96.5 lbs/hr 0.586 BSFC
8200 165.9
8300 163.8
8350 162.0
8400 159.9
That’s very fat in Polaris land. We had many at dtr and leaned them out to a safe 13.2:1 or 13.5:1 and gained 5-6 hp and 2-4 tq with a pcv.
Look at the test Darrin H from Polaris did @13:1 afr. It was 173 hp.
Lots left on the table here which is good .
