I noticed on the Assault version they put the running board supports back on them.
They're comp tracks are bulky stiff buggers, not like either of the other tracks.
I've seen them on several pro rmk's and they weren't on the assault rmk that I rode. I believe they will be a polaris accessory.
They (design engineers) know there are aspects of improvement to be had and almost everyone has been proven already in the aftermarket field but it all has to be a balance of economics and performance to a WIDE range of user groups on the same vehicle. Physically doing such things are way more difficult then conceptionally arm chairing it.
Trust me gang...its all aspects of how our stuff works that makes Better Boards the best and there is absolutely no way that without an insert the factory can compete heads up. Exactly the same as the XP and the newer M series lineups that offer a similar evacation style footbed. THEY STILL DON"T COMPARE TO OUR PRODUCTS FOR EVACUATION OR TRACTION. They are VASTLY IMPROVED but not as good as they could or should be! As a consumer you should be irked...as a manufacturer who makes his eating money on this stuff I still get to have a job because they just can't get it as good! That is why nearly to the man, knowledgable guys that actively ride our products then compare to these newer designs still see and feel the value of Better Boards and have gone to the trouble and expense to add them.
How it works:
You need larger evacuation holes and that requires a heavier stronger foundation. You need a taller and more aggressive cleat in unison with the size of the evacation holes or the snow holds in place. How much or how difficult it is to get off our through depends completely on the water content and temperature of the snow in question. Having a 360* raise simply traps and actually increases build up with bonding. With the design weight limitations of the entire vehicle they have a limited option for the heft of the base metal. The strength value of what they have to work with limits the cleat height to under 3 mm and must be rolled to 90* or they would just bend. The angle of the cleat bend and the pattern of the cut are critical for actual traction even when there is some snow trapped between the rider and the boards. This is all stuff we learned by manufacturing and testing thousands and thousands of products for millions and millions of FIELD USE RIDDEN MILES. Polaris should have done you all a favor with this sled and contracted us to build those parts for them with our expertise and experience instead of trying an end around. By prepping the cutout base in the footbed and automated riveting or using their new nasa glue process this could have all be done super easily and you guys would get a superior performing brand name product on your expensive hot rods for the same money.
From a rider standpoint:
I am accustomed to how Better Boards feel and work and actually made a manuever and slipped off the side of the DEMO 2011 and up ended it. Other testers (name guys like Burandt, Adams, Struthers, ect ect) who've all have now ridden both made the same statement. Our conclusion was for the common guy who doesn't know there is a difference the new boards are an awesome and huge improvement. For us that do we'll just have to get Better Boards if we want the best for 2011..simple.
Braaaaaaaaaap
I thought it was recommended not to run those on the raw tunnels...
Having ridden a 2010 M8 this year (and sold it) I can tell you that the Pclaw is NOT god's gift to tracks. That thing trenched like a beech and got walked all over by an XP any time the snow was soft. With a base it could hold it's own, but I sure wouldn't waste money on changing to one, unless my sled came with a 1" lug.
This is what I would have liked to see. For a good reliable stocker
4) Won't ever happen.
Build a very very mountian specific sled, turbo, titanium, etc, you don't need a rmk, summit or m series in the mid west. Build a limited number of true mountain sleds, and sell only to mountain dealers. That way they could control warrenty issues and other problems. If Polaris did that I would buy one.
