how to get rid of the bulky stock warmer switches
P
pylon
Hey guys . building my nypex and looking to to get rid of the stock warmer switches all together or at the very least make the nytros switch work because the warmers are all on the brake side . I ve seen a few rsi kits for sleds that move them off the bars and into a nice little cluster . thanks :face-icon-small-coo
I want to ditch mine as well fastrax makes some nice compact handlebar switches, I'm just worried that when I do some makeshift wiring, how easy the computer will see a fault if I put both grips and throttle warmer off the same input.
We do not have a kit for the Nytro but have these universal switches available for customization.
$19.95 each
cool ! have you done a nytro ? any ideas what wires to tap or cut ? as well if it will throw a code ?
Those are way too bulky. Get some momentary toggle style switches and mount them to the dash, they even make rubber booties to cover them at most auto motive electrical stores, we even do this for our keys so it is a keyless start. Way cleaner and no more bulky switches on the bars, just brake and throttle.
Here is a pic before I did the ignition but you get the idea.
We currently do not have any available information on the Nytro.
Our switches may seem bulky in the picture but they are the same size as the Polaris switches. Our design prevents switches getting broken off from impacts by your body or trees. Toggles can easily be broke right off with ease.
Thank you,
RSI
LOVE It ! thats how bars should look ! how did you tap into the wires? any codes come up with that done ?
They wire into stock harness, no codes at all. All you need is a momentary style switch, both directions that returns to center and use your negative and postive wires accordingly and thats all.
