What is the procedure on turning the oil pump up? My 2011 only has 200 miles on it but I've already noticed it uses a LOT less oil than my 08 D7 uses.
dabull has any of them had their oil pumps turned up when you gettin the new d max nieghbor
and TURN THE OILER UP....needs to burn 1 qt in a tank of fuel...adding oil to the gas does not lube the crank since the injectors are in the transfers and point up...
if you look at the injectors..they sit in the transfer ports, and the tip points up toward the chamber....makes it pretty tough to get oil/fuel to the crankcase..turning the oiler up does put extra oil into the crankcase..maybe a good thing would be do both, turn the oiler up, and add premix...According to SLP the way this motor oils it does a great job of getting oil to the crank. They highly recommend adding an oz of oil to every gallon of gas in every tank to lube the upper half of the motor that never gets oil. They claim they have tore into several of these motors and the ones that have been running a premix oil on top of the factory oil settings look far better then the ones that haven't. Just what I was told, been mixing in mine the last 150 miles and haven't noticed any difference in performance guess we will see how it holds up.
The 5 gallon can warning is just so you can do the math easier. It's not going to hurt if you add it directly to the tank. The way to do it is top off your tank, your tank holds 11 gallons (if I recall, could be wrong). So you do the math with 11 gallons of fuel. Either way the oil is going in the tank and is actually going to be more accurate if you mix it in the tank. If you mix in a 5 gallon can then you're not taking in to account the fuel that's already in the sled so it would be an incorrect mixture...
I'm not sure how all the other dealers work but when I bought my sled they already had the correct amount of oil added to the gas tank and told me just to top off the tank and go ride it. They recommended that only the first tank be premixed for break in. Premixing the tank isn't going to do anything to help your crank bearings. It never makes it into the crank case. The only way to add more oil to the crank is by turning up the pump.
