The transfer ports are open to the crankcase so when the piston comes down it pushes the air from the case reed air intake up the transfer ports to the top of the pistons. While doing so it also pushes the fuel that the injector sprayed into the transfer port to the top of the piston. So there may be minimal fuel that gets down into the crankcase but very little so adding oil to the fuel will not likely benefit the crank but should give the pistons and cylinders a little extra lube when it comes out of the transfer port on the top. So throttle body injection injects into the throttle body and comes in the crank with the air, semi direct injection is straight into the transfer port and the fuel gets mixed with the air on the way up the port and direct injection is directly on top of the piston mixing with the air right before TDC.
Exactly right........the only reason I questioned vftrader was because he said " no gas touches the crank ''
I never said that all the gas goes down to the crank, I did say some goes there. or in your words " so there may be minimal fuel that gets down into the crankcase " minimal is not none. when the injector opens most of the fuel will be taken up into the combustion chamber, but not all of it!!! yes the transfer ports have to be open for the motor to work. but I was talking about the injector port. If no gas period!!!! is suppose to be in the crank then why is that one open to the crank?? I believe that there is some or minimal gas that ends up in the crank housing, and then mixes with the air and oil following through the transfer ports to the cylinder for the next power stroke.
And I agree that adding oil to your gas will do little or nothing for your crank and bearings, That is why some of us are turning up our oil pumps.
IMO from the wear that I could see on the intake side of my pistons, I will be adding a little oil to each tank too help with any wash that might be happening.
I do understand how most of these motors work!!!! but I wanted vftrader to explaine how absolutly no gas touches the crank, when the injection port is open to the crank. I am always open to learning something new
