GEO YOUR INPUT?
i have asked this of you a few times now and you just avoid it...
Sorry, lol. Didn't know I was in school.
Theshhold for det sensor has to be low enough not to be set off by all the other things that rattle around in and on a sled motor. You know: pistons, pins, exhaust, ex-valves, recoil, wieghts,,,.
The best crank in the world won't beat det but better material-treatments and more needles will prolong the inevitable.
Rod design changes to let more oil in is another thing completely. I waited patiently lol as Doo (early 800's) went around the world in rod design. Floating to tight shimming. No thrust to double thrust. Double slot to single slot to side inlet to everything above lol.
Why the learning curve? EPA. Cure? Electric oil pump and enough inputs to the engine management computer that you are almost flying by wire on a Doo today.
One thing most crank guys like to see in their motors is a small fishing pond of oil in the bottom. Probably because if you do something for living all week long, you don't want to be thrashing on Fri. night on you weekend warrior lol.
Slight det or big det lol, is easy to see on the tops of your pistons or piston.
Trouble is, it takes careful observation, from many experiences, while learning, with pyros and jetting down, to bring up temps, that keep going down, for unknown reasons lol, until, after a few mistakes, you hit your head with your torque wrench, skip a day of school, to test your new theory of jetting with pyros and learning that the piston tells all lol, to make it easy to see.
Best as I can describe how slight det looks Kiliki is, excessive wash (to prove you are safe) with the exhaust port width still dry and carbon crown receding slightly towards the center.
Hope it helps.
