How do you know if you need an anti stab kit or not
Just curious, have seen this come up a fair bit. When I was putting my track back on a few weeks ago I noticed that the end of my rails are bloody close (1-1.5") from the track drive assembly. Also the plastic caps on the end of the rails are a bit scratched or cut up a bit. Not sure if that means its sometimes hitting the drive assembly or if its just from snow/mud/dirt getting in there.
What are the requirements for an anti stab kit?
Ive read that its for 3.0 pitch only? Is that correct? I believe I only have 2.52 pitch.
I have a 162 track on stock 159 rails (i believe, thats just a guess really)
The thought of a rail "stabbing" into my track at top speed along a trail is kinda unnerving. :D
In the opinion of many, if you have a 3.0 pitch track you need an anti-stab. Cheap insurance against a bad possibility. Otherwise not needed. Easiest way to tell if you have a 2.52 or a 3.0 pitch is to simply measure the track. A 3.0 pitch track will be 3 inches from one lug/drive window/drive nub/etc. to the next. A 2.52 pitch will be 2.53 inches for the same measurement.
If you slid the suspension to take up the difference of the 159 which is hard to believe because the 159 is 2.52 and the 162 is a 3. I assume you went to 3.0 drives with the 162. I did a set back 2.3/8 of inch and the track would kind of wrap around and hit the end caps so I put anti-stab wheels to keep the caps from getting beat up. The 3 pitch can find its way through the window if the stars align and you have an Obama/Al Gore moment. That is why you hear of guys running wheel kits on the front of the rails.
It was like this when I bought it 12 months ago. I had the drive assembly out a few weeks ago to change the bearing over. I counted the teeth on the assembly and from that I thought I had figured out that I had 2.52" pitch.
I guess the only way to know for certain is to check the track. Its a camoplast track, not sure if its challenger or challenger extreme. 16" wide. 2.5" lugs.
Anyway, a quick tape measure of the distances of the lugs should tell me
