I love what Andy did to my shocks. It's a totally different ride running down whopped up trails. I am still trying to figure out air pressure though. At 200lbs. I think I am at about 63 left, 60 right and 110 rear. Rides great, but what it will be like in the deep is still undetermined.
Aaron
P.S. As far as the air canisters, I can see them as a trail rider, but in the powder can't see needing them. JMO
I tend to disagree. It is apparent due to how low you need to run your air pressures to make a decent ride. The canisters work for all conditions as they allow for more air without the harshness in the inital part of the stroke. I weigh 165lbs dry (180 geared up). I'm currently running 73 left 70 rt and 130 rear and its working great. Two rides ago I used a little less pressure, which I might try splitting the difference. I like the support of the more air, meanwhile it is plush. I highly recommend Andy Youngstrom's work! Fast, and VERY reasonable in price.
Dude, not to be calling you out here, but aren't you the same guy that went riding with major clutch issues and it was because you had not even set your deflection after reclutching?
http://www.snowestonline.com/forum/showthread.php?t=187853
If you are going to disagree with people on here, you might want to know what you are doing with your sled first. Just saying!
Aaron
