The boondocker kit out of the box leaves alot to be desired. It's not my first go round with turbos so i knew exactly how to fix their flaws to make the pro run like it should. It was also my first experience with the boondocker control box which is a little confusing at first but as i learned how to use it, it gives me a little more tuning than a dobek (which are on my other turbo sleds). First day out i couldn't go over 7lbs boost with 50 AV and Premium without hitting DET(7k -10K)! But according to boondocker i was the only one having this problem, told me to change clutching and still the same result! So at that point i figured like all my other turbos i would make it my own kit making a few minor changes.
It now runs stronger at 7lbs of boost than it did at 10. Ive increased my fuel on high rpms to upper 40's to also prove that i'm creating more horsepower than the kit they sent me with numbers in the mid 30's.
The sled runs better off bottom end than our stock pros with zero lag! It's definetly a keeper. The best and most fun sled I've ever ridden.
First, only, and last issue is heat!!!! When engine temps get to 155 u hit DET, when charge tube temps get to 185 consistently u hit DET. No intercooler is needed, just put on a cold air intake and you will be amazed. But beware you will b tuning all over again with all that extra horse power. I'm pleased with the kit now that i have done the r&d myself. ONE big mistake is that they didn't go with dual injectors!! Currently running up to 11lbs no DET on 50Av and 50 premium.
