Rubbing significantly after 300 miles. Need to replace the hose, pretty deep gouge. Thanks for noticing this I would have been losing coolant pretty soon.
Just tied mine up, it was rubbing on one bolt lower than the OP's hose was, awesome find! Just notified a couple buddy's about it, same issue. Thanks a lot!
Mine isn't rubbing.
Guess mine works as designed....
I wonder if they just cut that black rubber coolent tube a bit to long on some of the sleds causing the whole thing to sag
Mine is rubbing which lends credence to the post above. I ordered another rubber collar like the one in the photo above. I will install it where the hose is rubbing on the Allen Head. It is a $4 part. I like that fix versus zip tying the hose away from the bolt. Zip ties break pretty easily, especially where there is a lot of temperature variance.
Mine isn't rubbing.
SMF... Are these rubber collars actual products in different sizes for this purpose... can you point me in the right direction for this.?
In my line of work, i'm always looking for abrasion sleeves that are clean and fit well.
Thx
That rubber collar slides over the factory power grip (hose clamp).
Zip tie just holds it there.
1" alum tube.
Got it... but where do the collars themselves come from??
Thx in advance?
