J
I just put a holtz rear that I bought in my 02 156 700. the holtz instructions said to set the front shock preload at two turns more than it takes to contact the spring and hset the limiter settings fron 5.5-6 inches of clearance fron the front arm to the rail I set it at 5.5. I took it for a short ride and it steers pretty heavy but rides prety well on the bumps. I noticed that there is slack at the top of the travel and when you lift the rear bumper up to get rid of that slack the front of the track gets pulled up off the ground. The raer does seem to sit a little low because of this slack at th etop of the travel, do you guys think the thing to do would be to rry it with the limiters set out to 6"? what are you guys running for settings and what else should I know about setting up this skid?
