Red is plat dots are rivets. Go around the hole with lord's put the plate down and rivet it. 3/32 rivets. 1/8" or so thick aluminum plate. You can also use 3m auto body panel adhesive instead of the lord's adhesive. Not sure of the # for the 3m though I've always used lords.
Sent from my SM-G965U using Tapatalk
Fastenall or amazon your best bet up here in Montana, if you were close I could fix it here with you take a hour or so, in Hamilton....if you use the glue you can actually use the fastenall stainless normal 3/16 rivets, they are plenty strong
You could also do a nice 1/4 inch plate the entire size of that bottom "triangle" area and glue and rivet it in there, never break and have a nice bash plate to boot, and would look good also...below is a picture of the area only way I could get it loaded lol
https://scontent-sea1-1.xx.fbcdn.ne...=a7a0283b219095df9623edb66005baf7&oe=5D1F28C7
I would personally do it that way vs the small patch.You could also do a nice 1/4 inch plate the entire size of that bottom "triangle" area and glue and rivet it in there, never break and have a nice bash plate to boot, and would look good also...below is a picture of the area only way I could get it loaded lol
Use 3/16 rivets I told you the wrong size earlier in a post.
I would use the larger head style rivets.
Nice job. Looks good.Here it is done. This should be the best you can get it without new parts. IMO
Ahhh...the sport of sledding, i often wonder how much $$$ i would have in the bank if i sold everything and took up knitting and tea...sweater anyone?
looks clean, nice job!Here it is done. This should be the best you can get it without new parts. IMO
