V
Vi-PEC Powersports
"Connected" would have made more sense to me....sorry.
This language issue is, sometime, misleading people.... Trying to do my best but ain't enough obviously.
Vi-pec powersports
Nothing says you can't still test at all elevations...Thanks Die Hard, perhaps I misunderstood SH, will ask about it tomorrow or test it at various elevations and see what happens with the current sled set up. Hmmmm, sounds like a road trip to me!!
First method cheaper, second more fun.
Well I put an expensive liquid filled auto meter guage on my HM kit, I'll have to go into the Vipec and download what it says for boost, my guage is reading 7 lbs. I'll keep you posted on if there is a varience. Now I did personally see a HM sled at 6 lb on pump gas, run neck and neck with a silber on Ave gas 10 lb. IMO,The water to air intercooler is what makes the difference, this is why alot of Turbo drag cars have an ice box to cool the air. Denser the air, the better. The Vipec is just a nice expensive addition to make the sled a Pull the Rope and play. My turbo was installed at home, 3 pulls and sled started and ran great out of the box, we just had to adjust the primary weights that come with the kit. Very smooth no turbo lag.
Id have to see it to believe it. If anyone around the bighorns is running a hm turbo let me know. Id be curious to run with one.
I agree pinit. Im sorry but i dont think any kit will just destroy another kit at same boost levels unless other factors come into play. Worn out motor, bad clutching, fat rider, Bad tuning, etc. etc. But Hey i can be proven wrong. I believe i have a pretty well running boondocker kit. I would love to make the turbo days in cooke but im on call that week. But a true test would get 2 pros. 1 with one kit, the other with another kit. Set it up exactly the same, same suspension, same track, same clutching, same boost with same gauge in same location. Then run them thru the ropes.
The variable vane turbo is a far more efficient turbo than a standard turbo. There is a book out I picked up in a performance shop called real world performance turbo charger systems u might want to pick it up there is a lot of useful information in it about boosting. Its on 4 strokes but u can still get a lot of info like compresser mapping and how different turbos do different things its good reading.Me I'd never run a turbo without an external wastegate I love the variable vane turbo but there problematic but they spool fast jmho
Boost really doesn't mean anything though. It is more of a measure of backpressure from your motor and turbo kit... The actuall amout of air (CFM not pressure of air) is what matters. Take a regular little 2860 internal gate put it at 6psi, then take a bigger say 3076 and put it at 6psi boost they are not even gonna be close the bigger turbo is gonna detroy it.
Now put an effecient W/A intercooler on it, a Tial housing and external gate, More efficient Billet compressor wheel, Ceramic ball bearing senter section, Run more timing and leaner AFR's with the Vipec..... The list can go on and on how one kit can be better and more efficient then another.
Not saying that the BD and HM won't be close but saying that if you just set all turbo kits at the same Boost and there gonna be even is wrong... There are just so many factors that play into a turbo kit.
Boost is the only thing you can keep the same to compare these 2 kits. They both run different turbos.[/QUOTE
I think you missed what I was trying to say
Yes I know they use different turbos.... What I am trying to say is because they use different turbos the result is gonna be different at the same boost... You had stated earlier that you think all kits at the same boost will be the same power.... I disagree
