HIDs
what kit are you using?
What wattage do the high beams require?
My HID's in my 09 D8 are low beam in HID, high beam in halogen.
Do you have the wire from the ballast to the bulb backwards?
Pretty vague problem analysis there....
if im not mistaken, the xp's run ac voltage for their headlights, and not dc like polaris. if this is the case, you will need to install a rectifier to convert the headlight voltage to dc.
your kit that u ordered is prolly just a single beam and will only have a hi or a low and now both.
