Great info.
Are there any other advantages/disadvantages in up grading my Dish package to HD?
Such as.....
Will my dish hold signal better or worse in rainstorm? etc?
Mafesto...
A 1080p TV will not enhance your Dish signal. There are very few 1080p programs available. No sports network broadcasts in 1080p yet. Where you will see the difference in 1080p is in DVD's, particularly Blu-Ray (wow! what a difference). Most brands don't have 1080p until you go bigger than 36" simply because you can't see the difference until you get a bigger picture. But, 1080p is just around the corner.
By the way....the bigger the TV you go to the worse your standard Dish broadcast will look. It is simply stretching and displaying a poor signal on a bigger screen. Go to HD, you will never look back.
i will answer that one for you, I upgraded to Dish HD and the reception in snow storms is terrible. Worse than my old standard dish. Havent had a rain storm yet where i have lost reception.
If your going to do dish HD you should have at least a 720p tv and run it off HDMI cables not the component cables. Once you go HD you will never go back... LOL
This along with their terrible service led me to Direct TV (long ranting story...).
Yep, snowstorms are harder on Dish's reception for some reason (I don't have this problem with Direct TV). I would loose HD in snow storms but regular TV would be fine (non-HD TV). Dish's HD receiver is very buggy (they acknowledge this themselves). I had two returned and still had issues. This along with their terrible service led me to Direct TV (long ranting story...).
I disagree with Dangerfield on the HDMI. I have been able to tell the difference between those and component cables. My Direct TV installer gave them to me for two TV's for free. But they are expensive. Perhaps it depends on the provider and TV.
most of my best friends worked for dish for a long time... never had any problems when i needed customer support, however now that they have moved on if i ever encounter customer service problems im going to direct tv...
I can tell a difference between component cables and hdmi. As stated to get full hd 1080p you must have hdmi. However, i bought some HDMI cables on a website for like $10, and i was given a couple of the $100 cables when i bought my TV. I cannot tell a difference between the expensive HDMI cables and the cheap china hdmi cables.
Monster = JUNK! I would never waste my money on that stuff.
OK so I shouldn't call it junk but it is a waste of money. I did some test in college on cheap vs expensive and there was NO difference in the cable.
What kind of testing? Bandwidth? Noise rejection? There is a difference between cables and cheap cables... but yeah, monster is overrated. Connectors are where most of the noise comes in, anyways.
Used a bunch of 50Ω coax at my last job for small signal transmission (~2mVpp) over 100ft lengths... had a high frequency generator (think handheld tesla coil... ) and looked at the noise on the coax on a 'scope.... Not surprisingly, as the noise was injected closer to the connectors the more noise went onto the signal on the line. The cable with the foil under the braid on the shield works the best. Make sure the drain line on the foil is connected to ground, some manufacturers miss that.
