O
Original Tetonice
I can only speak of my own experience. I did exactly what I advised the previous poster to do i.e. 19tooth gear, remove pin weight (because we are riding at 10K feet). I had no belt issues, primary was not hot to the touch and I would pull great out of the hole & climb great (even though first tank of fuel.. running rich) and still shifted all the way out & reached 80mph on the trails... IMO, it worked! IMO, if you have some knowledge to pass along great!! But, it might come across better if didn't seem as though you are "the clutching god" and the rest of us have had no prior experience or at least are willing to share what we know without being offensive. GO RIDE!![]()
Dude here's a dead give away........( even though first tank of gas...running rich ) LOL Skdoo's historically don't run very well until they get at least 300miles on them. And at 10K your not hitting overdrive, at 10K in deep snow your sled is down 30% of it's power and working real hard to stay aflot..Ggo out and look at your clutch sheaves, Im willing to bet you have at least 1inch or more until your at or near the overdrive.
Im not here to be the "clutching god" just calling BS on running NO pin weight. FYI your pin weight should be used for nothing more than dialing in your RPM...More pin weight will drop your RPM less pin weight will increase your RPM, it's that simple.....The shape of the ramp(s) will determine how fast or slow the arm(S) that push against the ramps will upshift. The Primary Spring dictates side pressure as well as engagement. A softer springer will typically engage at lower rpm's while a stiffer spring will typically engage at a slightly higher RPM.
The trouble with springs is there always changing getting softer as more miles are logged. When i buy a new spring before i install the spring i sqweeze it in a vise over night to break the spring in, knowing full well that the stiff spring you think you bought is getting softer and softer every time you ride....The cheap "coat hanger wire" spring that comes with your XP are not of the highest quality and because there always changing (getting softer) can and will have an effect on performance, belt wear and excessive heat.
OT
