SWEETXPBEATCH
belt alignment
Do you think it could be that silly secondary bolt. We adjusted a friends this weekend & honestly, I think he overtightened it & now can get it tight enough without loosening the sheaves. I don't know if that makes any sense to you or not but basically the black ring just spins now when he is attempting to tighten the inner bolt?
hi guys, sorry about your troubles, i have an 06 rmk belt eatin mofo. many had no belt issues, i had lots. did everything humanly possible... clutching, weights, motor mounts, slp torque stop, push arm, venting, belt aligning, gearing, break in, soap n water, 3 different types of belts, nothing could get me to go 100+ km on a belt. dealership blamed polaris, polaris blamed dealership setup. finally i asked polaris to tell me how to set it up then went to dealership and worked with the mechanic to set it up like the factory said. cords showing out the side means belt misalignment. the torque on the motor shifts them out of alignment and it doesn't take much. set the motor slightly out of alignment very slightly so when the motor torques it lines up perfectly, then allowed the secondary to float 1/4 inch inward of alignment. problem solved. finally, 14 belts in 1200 km, now 4-500 km per belt with slp mods, and nos. (i am running the new super belt also but ran the normal one with this setup and had good results.) the vibration issues we'rent on all sleds on polaris either, this was a result of poor tapers on the crank, set up a dial indicator and see how far out the clutch moves when turning it. some polaris's would change 7 thousanths in a revolution, i removed mine and put it right back on 3 times and the third time i was down to 1.5 thousanths in a revolution. vibration gone. your xp's are going to be great sleds, you'll get er figured out...good luck. at least u dont have a tank to start with like i did. cost me a pile to get under 500lbs.
