HELP...WTF sled wont rev.
sledracer
99 machz...the one Ive been asphalt racing the last few years has a problem.
Ive moved and dont as of yet have a shop, the sled sat outside all winter (covered). I pulled the sled out today and started it up. It fired right up and idled as usual. After letting the sled warm a bit I blipped the throttle a bit and found the sled wont rev over 3000 rpm. This is an electrical issue I expect as it sounds exactly like it did when I had a starting line rev limiter in it. I can try n sneak up on the RPM at part throttle or whack it wide open and the result is the same, hits round 3000 rpm and quits reving. I did remove the stock hood and swap it for a lexan one. Simply unplugged the wire harness...I dont think this would effect anything as Ive ran it this way before; I did put the stock hood on and plug in the harness...didnt make a difference.
Any thoughts? :confused:
Tyler
Mine did the EXACT same thing, ended up being a DESS key, but something is still fishy with it, it will do it every once in a while, but only for a few seconds, and only on low-beam headlight!
Interesting...I will check the tether tomorrow...dont expact the neighbour wana hear the crack of triple Jaws pipes at this hour :D
Any other ideas - if I can get it sorted Id like to go to the track this weekend for the first time in a couple years.
You nailed it!! The tether was loose, probably got messed up pullin the cover off or somethin silly. I never even considered it. LOL Thanx
So how do you go about erasin a thread on this new forum??:mad::face-icon-small-win
