I’ve got a 2006 Summit 800HO PT Adrenalin with a fresh top end kit installed.
Here’s the problem since the rebuild.
When you pin it WOT it revs up fine. Takes off like a bullet. Reaches 8000 rpm then studders, Drops R’s a little then back comes the power. Studders again power drops a bit then comes back! Does this several times then seems to go away. It’s most noticeable when first leaving the parking lot after starting the machine. (After warm up)
Is this symptoms of the Deto sensor going off? Does the engine temp have something to do with it?
Is there a Rev limiter on the 2006’s?
Thanks in advance!
Thanks in advance!
