shortstop20
No, you can't use your clutch bolt because it threads into the crank, you need a bolt that threads into the clutch.
Doesn't anybody use spanners with the pullers anymore? I have done it this way for over 20 yrs.
Yes, the $3 hardware store bolt trick works with water/grease/oil/brake fluid/whatever. Of course whatever you put in there splashes a bit when it breaks loose. And last I checked brake fluid eats paint...so I personally think that particular liquid is a terrible idea unless you don't mind causing some permanant cosmetic damage to any nearby painted part that hapens to get splashed.
Water is a heckuva lot easier to clean up because you don't have to. It just disappears. But the threads need to be sealed very tightly because the water flows so easily it can seep past the threads and you lose some force. With an impact wrench that's fast enough this doesn't matter. Grease works best if you're pulling by hand tools, but is hardest to clean up, and harder to get air bubbles out of the grease so the method works. Threads should be lubricated with grease, oil, or something anyway to prevent damage to the threads of the bolt and more importantly the clutch, as well as to maximize pulling force that would otherwise be wasted on overcoming friction.
And there is no possible way that the rotational force provided by impact wrenches will harm crank bearings. If those bearings can withstand the violent rotational forces that internal combustion explosions under high compression create...especially with today's electronic reverse systems where one massive explosion hits the connecting rod bearing so hard it actually spins the motor over 180 degrees in the opposite direction from a dead stop? Man...a series of impact wrench hits is merely love taps to those bearings. But I do suggest not hitting the end of the puller with a hammer as some do to try to "break" it free. Such non-rotational force can be very damaging to crank bearings and maybe seals if you manage to actually move the crank. You gotta just let the impact's rotational force do that job...
I betcha over 95% of the dealer techs out there are pulling customer's clutches with impacts every day...
