Help! Installing new bearings in a 2004 TRA?
Mine are shot in the primary. 3300 miles is that common???Can anyone give me info on removing old brass bearings and installing new ones? Steps???? loctite??? Removal??? installing???
Thanks!
that's about right for clutches to go bad .i would have the dealer replace the main bushing get new slider shoes and govoner cup and while u are at it put in new spring ,ramps could be bad , if u have the tools its easy. look at your driven clutch to . :beer;
It's not that hard if you want to do it yourself but make sure you get a new clip for the main bushing. You usually end up ruining the one that's in there to get it out.
Also use red loctite on the main bushing and the spring cup bushing. You can also get just a new spring cup which isn't a bad idea considering the miles.
