Hello
You might have to take the front plastics off and the exhaust pipe off to look around, the nun can be bent but in areas not easily seen, my right ski set back a touch more than the left, the one area I noticed this is cause the shock spring doesn`t set as centered in the middle of the top control arm than the left, the front of the right shock spring is close to touchin the inside of the control arm and on the left there is about 3/8 inch gap between the two, I also couldn`t see anything but at least on mine I noticed a tweek in the side of the bulkhead as I changing the exhaust can, I hammered it back straight but I know when I take the front plastics off I`ll definetely find more to my surprise,
I bet you will notice more too.
the aluminum pieces coming up from the skis is the Spindle.. and the top of the spindle should be setting at a bit of a back angle, the top back farther than the bottom this is the caster angle in the front suspension.
Good Luck, Wildcard
