G
geo
Geo that is good info. Would have thought ALL fluids but gas and two stroke oil would weigh more than 12 pounds over "dry" weight. Do you use your scales to set a balance on left and right side weight and a balance to skis to skid weight? Just wonder how technical you are on set up? Corner weights and balance front to rear is so important on road race and circle track cars. I have no idea how important that is for sleds.
MM, oil 4 or 5ish, coolant 7 or 8ish, shock oil 1/2 to 3/4 ish lol, pretty closeish lol.
But you missed my point I think. It's not the "ish" parts or if my scales are deadly (but for me it will be my comparison for my goal of 400 lbs. crate weight). It's the fact that we are 40 or 50 or 60 lighter to start. Those are the big numbers that should make us all feel giddy.
No I don't use the scales to balance the suspention but it was useful to see the sometimes huge differences from RH to LH. The poo is much closer than most.
I set up my front tensions with me on board fully geared (backpack and all), rear set to your needs and fueled.
On the Pro disconnect the sway bar, stand on the sled in riding position, one foot on each side, pull over to lift the RH ski off the floor, then do the same to lift the LH ski off the floor.
The effort to do either side should be the same. this can be adjusted with the front springs by adding tension to the side that is easier to pull up and subtracting tension from the side that is harder to pull up (one turn on both sides at a time).
Once done on trail changes should same # of turns each side.
Reconnect sway bar because IMO it is one of the reasons the sled is so easy to ride for such a broad spectrum of rider styles and weights.
