sykosledhead
08 D8 with pump gas turbo. Just finished total rebuild running 50/50 110 and 91 pump with extra oil for first tank. Ran it on stand for a month or so to seat rings. After rebuild, idle was slightly fast. Ran it twice in Snowies, just goin on road to break in. Went of drift and sled wouldn't run. Unplugged TPS, works fine. Took it to Polaris and had TPS adjusted, baseline and TPS good. Now since then if you don't open the throttle with sstart, won't fire up. Open the throttle some and it fires and runs ok with some gas. If you let off, after about 5 secs, it goes into limp mode and dies with a little gas. If you open the throttle, it runs ok, let off it dies after 5 secs. Its on the video but hard to see.
Any ideas? I want to rerun the ground, check the reeds, check the skirt of the pistons, and check for leaks in the intakes. I put a new intake boot in with the rebuild so it should be ok.
http://www.youtube.com/watch?v=a4iFgqbzAN8&context=C3d85480ADOEgsToPDskLpEVFch5LGZg5pvs1dtVlL
syko.
syko.
