O
Set park brake,remove top bolt holding the rotor. remove brake caliper an setout of the way.remove brake rotor, pull sleeve off top shaft behind rotor. remove o ring from groove behind splines then remove cover. loosen chain tensioner then bottom bolt. remove top and bottom gear along with the chain. install new 19 t gear and reverse to assemble. easy cheesy!!!
