update..... utah took off the big 2876 and is going to put on a 2871. should work alot better for him. .86 housing. JMO
I run the 2871 with a 2.5" charge tube and this is a totally different beast than say a 2860...especially at 10k plus. you can definately tell the difference on the mid and top as it pulls much harder than the 2860. Be prepared to change the jetting as it is not just simply swap the turbos and roll. a little higher engagement helps the 2871 at higher elevations.
So realistically, if a person is not looking for more power is it worth changing the turbo? I've swapped pistons and it does not look like I am getting to much heat from a small turbo, no reed issues, and response is extremely fast. Spools up much faster than the OVS tial setup I've ridden w/ on a Cat. My sled has a 2860.
Utah Sledder, do you plan on changing the 2876 to the .86 housing at some point so you can compare to how the 2871 is going to perform?
I know I am probably going to get flamed and I don't ride a doo but for 6-8lbs a 2860 probably cannot be beat. You won't see the benefit of the 71 or the 76 until much higher boost. I have seen a 76 with the larger housing spool much faster than a 71 at typical Utah elevation on a cat 800 even though I was not a believer until I rode it
Spent the weekend in Wyoming testing the big 2876. Like Bryce said a few posts back...I went back to the 2871. Hate to tell ya boys but my personal test did not prove the 2876 to be a better turbo than the 2871. I only ride 7-10k feet of elevation. The 2876 was WAY slower to respond and slow to build boost than the smaller 2860 that I ran all last year. I think it is extremely important to remember that a guy that rides at 1000-3000 feet is going to have a completely different set-up than a guy running from 8-10. It's pretty obvious that sea level stock sleds can run with a bunch of weight in the clutch but an elevation guy has to run zero weight in the clutch. This just proves that the elevation sled has less power, less flow, less pretty much everything. Gearing is different etc. etc. etc.
I personally tested this turbo for my own knowledge and fun. I don't see how/where Bryce is bashing anyone???
I'm a lover not a hater thus defintatley not bashing anyone, but bring your big dang turbos and low engagement sleds out here to my elevation and I am pretty sure your going to hate your set-up.
My conclusions...I know lots of guys are going to disagree with me here but for low boost 6-8 lbs above 8000 feet a 2860 (.86 ar) works awesome! If your a tree rider, 2860 kicks butt! I ran this all last year with 2300 happy boosted, pretty much trouble free miles. I would gladdly run this turbo any day of the week!
The new 2871 (.86 ar) has a little longer legs than the 2860 for bigger pulls and provides slightly lower charge tube temps (but I couldn't tell a difference). It builds boost much quicker than the 2876 and has almost the identical response as the 2860. My testing didn't show a huge improvement over the 2860...mabey just a slight drop in EGT's on a really long pull.
I only run 7-8 lbs of boost. I only ride at 7000-10,000 feet. So mabey the other bigger turbos work better for huge boost and lower elevation but my test proved it to not be a better set-up.
hmm, how could a 2876 be slower spooling then a 2871? the 76 is a bigger compressor, it moves more air with less, so it should actually Spool faster then the 71, should it not? because thats pretty much what ive learned so far....
Thanks for the update Bryce. Keep us posted how this one compares to the 2860 and the 2876. I would have already upgraded mine if it wasn't for needing a crank, pistons, etc...... Oh well, Maybe when I get a little more $$$ saved up...
After talking to several different turbo builders, they basically told me the same thing. If you ride 4 - 5000ft or lower the 2876 is the ticket. If you ride 8 -10000 ft the 2871 is the ticket. At elevation the 71 spooled faster and has similar top end. I had a 3076 with a .64 hot side and it wouldn't get out of its own way. Super slow to spool but had really good top end when it finally spooled. Then I went way smaller now im looking to go somewhere in the middle... Hopefully it will be the best of both worlds...
Well I just got back from a test ride with a 2876. I got it with a .64 turbine housing. It builds boost really quick....that being said it is definitely not quicker than the 2860 that I was using last year.
with the release of the new Garrett 2863 gtx turbos this will soon be the best setup for hi altitude performance. on the 800s. We have used modified 2860s in the past with good results. the gtx turbine wheel. should be the best of both worlds. we are testing one next week and i will let everyone know how it compares at altitudes above 8000ft. Thanks Rick
