Well I just got back from a test ride with a 2876. I got it with a .64 turbine housing. It builds boost really quick....that being said it is definitely not quicker than the 2860 that I was using last year. It is probably about a 1/2 second slower than the 2860. It does start building boost at about 6200 RPM and cruising it is running about 3 lbs of boost. The 2860 is building boost almost immediately after engagement which is around 5500 with white/white spring. I have my boost controller set at 8 lbs. From 3lbs to 8lbs the 2876 is really fast. One of the things I noticed is that my EGT's were way down from last year running the 2860. I assume this is from the bigger compressor pushing cooler charge air. Cooler in=cooler out. I think that I can probably improve the response of the 2876 even more by leaning out my mid range a little bit. It feels pretty fat from bottom to mid (at 10,000 ft elevation). I have the '07 needles in the middle position.
Anyway, just thought I would share my experience.
