You don't need it.
The ROX strap will probably work on the Pro-tapers but I'm not sure how well the other ones will fit. The mounts would have to be attached to the vertical part of the pro tapers correct due to the lack of handle bar room?The ones from ROX Speed FX are probably the best I've seen. Pricey but nice.
They call it the "snake strap" and it can be moved out of the way when not in use.
The Skinz Protective Gear (SPG) is sweet as well... and has very nice billet ends.
A good basic one is available from WPS that has a clean mounting bolt system
