C
Are we talking about engine response or track response? Two totally different things. I try to give an example what I mean.
Let say you are runninng 38mm pivot, cliker #4 and engine runs 8000-8100, thats great. You get that instant pull and rpm is consistent troughout the pull.
And your brother has 33mm pivot, cliker #2 and his engine runs also 8000-8100. His engine response is quicker. He probably gets some overshoot around 8200 in the beginning but longer the pull goes it drops to 8000-8100 which is fine too.
I would say you both have same sled but different qualities. It comes to personal preference, how and where you like to ride. For long pulls, drag racing, more open areas yours is better. For tricks, treeriding, etc. your brothers setup suits better.
BUT
if situation is that you both run 38mm pivot, yours is on #3 and his on #2. Probably whats happening is that your sled has consistent rpm 8000-81000 from the beginning, but your brothers sled has same rpm in the beginning but along the pull it drops to 7900. In this situation you can feel that your sled engages harder and pulls better. This is the reason I allways advice people to match pivot&spring to a desired cliker #.
I’m in a lower clicker, I’m on three in the factory position for the 761, he was on clicker 4, you have it backwards.
The third person in our group riding in the trees with us commented on how much my sled roosts with throttle blips compared to my brothers sled.
So to answer your first question, My throttle is connected to my track, and my sled is very snappy. Maybe you have not picked up on this, but My G5 does not have the factory clutching in it, it was the first thing to go. The only thing being used in my sled is the factory 761 ramps.
Again, My sled has way more mass in the pivot, lower engagement, lower clicker position than my brother’s stock G5, and we are both running the stock 761’s. We let the third person ride both our sleds back to back and he commented how responsive mine was over my brothers.
