We have worked hard in the 2015 reworked Gen II snow bike kit. In fact now its called GEN 2.5
![Wink ;-) ;-)](/forum/images/smilies/icon_wink.gif)
Finally, it's completed!
Can't wait or snow!
Our focus of the improvements have been on the suspension and reduce weight. Also fix some minor design flaws.
Notice that we have manufactured our own bogie rails.
Tunnel panels has a new slimmer design.
The drive shaft is moved forward 30 mm and up 20 mm.
New shocks. Fox float 3 with new length and stroke.
A new slider in the rear arm with ballbearings instead of teflon.
Here a comparison between new and old panel.
Reworked suspenson atatchment points. The whole suspenson package is moved 30 mm forward.
Drive chaft is also moved 30 mm forward and 20 mm upward.
During disasembly we saw that one of the tubes was broken.
Made a new tube with a 2 mm wallthickness and also a reinforcement.
All powdercoated.
Production of fork camps.
Start with water jet cut blanks
48 mm core drilling. Impressive fine cut and tight tolerances. Fits tightly around the fork legs very well.
Chamfering th edges for a nice look.
Using a router mounted under an old saw-bench.
The bit has a 10mm ball bearing.
Remains is to drill and countersink and last of all cut apart the clamps into halves.
Mill the first plane out of the outer diameter of allen bolt, 13 mm.
Then drill 8 mm holes.
Cutting the clamps in a band saw.
Since these clamps are more slender than previous hydralic clamps, now we can also mount the fork guards.
Some construction photos from the production of bogie rails. The reason we have chosen to make our own is to get the right length, the right angle , closer to the drive chaft as possible. In addition, we were able to adapt them to the new design of the sliding function. Last but not least, it is fun to do something of their own!
Made a drawing on the basis of our previous wooden mockup.
The idea was to get a high profile but with large lightening holes.
Had an idea of cutting out a text but it proved to increase the weight too much.
The rails are cut out of 8 mm aluminum.
Here you see the recess for the bal bearig trolley that will runs inside.
Milling a 4 mm wide and 15 mm deep groove in the underside of the 8 mm-rail
4 mm aluminumT-profile is only available as 40 mm. Cut it down to 25x14 in a resaw with carbide blade.
Rounding at the front of the rail, the T-profile is cut equally spaced so rounding is acceptable.
T-profile is inserted into the groove and drilled for pop rivets.
Done!
Here is a picture from our previous slide function. A plastic liner of Teflon-like material ran in the groove. Turned out to work out poorly with the combination of aluminum. The wear was greater than estimated. With ball bearings, we hope that the wear is non-existent. In addition, it rolls easily.
