gas can on slash tunnel
Since no Polaris option this year on a gas can rack. I also wanted a no required tunnel drilling option using the existing Matryx pre-drilled tunnel holes, so then I used some aluminum t-rail and works great!
Where did you get the aluminum t-rail?
@DUDEE
or
This brand has a thicker wall dimensions than most. Keep in mind that its not really designed for a 1/4" screw to go through it and still be able to move a 1/4" hex bolt down the rail, its really meant for small #6 screws. I did fab up a couple pieces for my Slash so I can more quickly swap between my tunnel bag and MoPro's rack and it worked really well. Just be conscience of the relationship between your tunnel mount and device mount since you cant slide it the whole way.
For $20 it will suffice until something better comes along in the aftermarket...
@DUDEE
or
Perfect.
