garage shop choices
It was a pretty sad start to the day, I pulled out that chop saw I posted earlier on to find out it no longer works
In the photos the diagonal tension members are still outside of the studs, correct?
I would assume you will fur (have furred) the wall out past them before sheeting it?
Dual exhaust on a 6.0 ?
Sent from my SM-G920R4 using Tapatalk
Yep the vertical 2x4 studs were inside the turn buckle straps, then the horizontal 2x3 pieces on the outside of the studs added up to the same width as the 2x6 sill plate
That was the easy wall now it's pretty tricky scabing in the rest, lots of funny business going to be happening here
Wood is good
New door frame
Why the narrower door? Why, space for this fine piece of sexyness!!
What is that on the left side of the piece of sexyness?
GS6
Ahh. Have not seen one without the meter and cover.
GS6
Looks like you were successful! Patience and persistence will beat force every time. Most of time it is easier to fish a rope / cable thru and pull them with a generous amount of cable lube, depending on the number of bends and how tight of a radius they are, some pushing may be needed as well.
Looking good! Hopefully that will rectify your electrical woes at your new location.
So now comes the question. I now have the power for my welder which needs 120 amps. I don't really want to hard wire it but it seems to be the only option. Unless someone knows of an affordable single phase 120amp plug and recepticle.
