Full roller speed drive wheels From Indy specialty.
Sheetmetalfab
Check them out on the eBay store.
Nice looking product... the description reads as if it is only a racing wheel for asphalt.
FROM EBAY LISTING for INDY SPECIALTY:
** JUST RELEASED **
HIGH SPEED ALL ROLLER 9 TOOTH DRIVE WHEELS, THESE DRIVE WHEELS ARE FOR HIGH PERFORMANCE USE ONLY.
AFTER EXTENSIVE TESTING ASPHALT RACING THESE ALL ROLLER DRIVE WHEELS WERE THE SINGLE BEST PERFORMANCE MODIFICATION WE FOUND.
THE STOCK WHEELS LOSE THE RADIUS AND START ROBBING TOP SPEED - A LOT OF TOP END.
WOREN DRIVE WHEELS HAVE COST US THOUSANDS OF DOLLARS IN BLOWEN BELTS AND SCRUBBED 8 MPH OFF THE TOP-END SPEED OF OUR 1000cc XCR IN THE 1/8 MILE = 660 FEET.
IN GOOD WEATHER IT WENT FROM RUNNING 114 TO 116 MPH CONSISTANTLY IN THE 1/8 MILE DOWN TO 102 TO 108 MPH
WE FINALLY REPLACED THE 2 DRIVE STOCK WHEELS AND REPLACED THEM WITH A 4 DRIVE SYSTEM THAT WENT TO 116 TO 121.78 MPH IN THE 1/8 MILE WITH NO OTHER MODS.
THESE WHEELS LAST MUCH LONGER THEN STOCK.
WE ALSO BUILD 10 TOOTH, 11 TOOTH & 12 TOOTH DRIVERS
DRIVE SHAFTS ALSO AVAILABLE.
THESE ARE A RACING WHEEL. IF YOU CHOOSE TO PUT THEM ON A PRODUCTION SLED YOU DO THIS AT YOUR OWN RISK !!!
** WE ARE NOT LIABLE OR RESPONSIBLE !! BUY AT YOUR OWN RISK ONLY !!! **
INDY SPECIALTY
23503 145TH AVE
WELCH MN 55089
651-388-9045
I talked to Dan briefly about these while discussing his LR motor and I believe you can use these on most sleds for standard riding applications although he doesn't warranty them like most of his products. I think he was just referring to his asphalt sled and where he witnessed the gains and benefits first hand of these wheels. At the bottom of his ad he says you can put them on production sleds. He told me that they just won't take the abuse that the stock drive wheels can because we all know how many land mines are hidden under the snow but he did say they are unbelievable as far as how "fast" they are. Didn't get into too much detail but hope this helps.
I would think the benefits would be less noticeable on snow, since you have snow to lubricate the the track and drivers.
