We're running 2 gallons of AV from Chena Marina in every tank with 90. One skidoo turbo and one polaris boost. Both run great.Roger that. Chad at A2D and Logan at the Outpost both recommended some kind of Octane boost whether Torco or AV gas. Currently I run straight AV in my Silber Axys so I think I am going to do something to get that Octane up for my new Boost. Sucks we only get 90 in AK.
Where is the pump exactly at Chena Marina. I live up the hill on the ridge and have been getting my AV gas at the East Ramp at the main airport for years for my sleds.We're running 2 gallons of AV from Chena Marina in every tank with 90. One skidoo turbo and one polaris boost. Both run great.
All my experience with octane and engine response is with 2 stroke engines.If your older than the jeans your wearing, lived &drove in the 70's and 80's and remember the impurities some stations had in their tanks peddling **** gas you might remember. They didn't mandate that a in ground tank replacements until the mid 90's in my state and pushed a lot of owners out of business. Before then, with my 73 Plymouth 318 V8. or 72 Nova 396 V8, or 70 Cuda 440 V8, 79 Ford Econoline "Shaggin Wagon" 351 Windsor Van. Changing fuel filter, pulling the carb, cleaning the carb and flushing the fuel line from a crap tank of gas was pretty normal. But, before going through that, a little 104 and or Heet would sometimes clear it up and get rid of that bottom end of hesitation before you have to go through all that. So yeah, it would "Liven it up." But whatev, I have no real world life experience that trumps google.
My main riding buddy swore the same thing on his 07 xrs but usually over octane mean less performanceFor some stupid reason 2019 850 axys liked 2 gallons of av gas per 10 gallons it would gain 300 rpms tested it more than a few thinking it was snow conditions but it wasn’t.
I'm a Eastern SD native also and do remember the 85 octane in the hills. I always found it funny that the Western side and much Higher elevation part of SD had such low octane fuel at the pumps. But in Watertown (my home town) we had 90-93 octane at almost all gas stations and still to this day! Luckily the Hills don't seem to get snow anymore so I don't have to deal with 85 octane BS.. Just silly that a place with one of the longest snowmobile / ATV trail systems in the world and hosts the Sturgis Bike Rally is still in the 1980's with the octane levels. (its changed some recently but still)Not Bolivia...But I think you might be able to see it from here. Black Hills. Before I moved here we used to come out in the 90's and early 2000's. Buckhorn, Rec Springs, Trailshead only carried 85. We'd top off all the tanks in Rapid City before going up the hill paying 1 1/2 to 2x as much for 85. In this state it's hard to find 91+ that isn't ethanol. I miss the days as a teen in Sioux Falls where you could pull up to a pump and put a bit of 104 octane in the tank to liven up the motor while the guy across from you it filling up his sprint cars to run Husets that night as he looks at you like, "kid your going to learn how to rebuild an engine real quick." but then you stop and switch to regular leaded and he realizes you just cleaning out the fuel system (pre injector cleaner days.). So many cheap quality fuel choices then for sleds.
Ok so kind of hard to explain but hear me out. If you go to the actual “chena marina” hanger that google maps takes you to, turn left toward the air strip, then take a right just before you hit the runway (don’t drive onto the strip), it’s about 200 feet and on the right under a little shelter with a light. You’ll see the hose reel and the pump. You’ll need an airplane tail number so I usually just use one from an old receipt nearby.Where is the pump exactly at Chena Marina. I live up the hill on the ridge and have been getting my AV gas at the East Ramp at the main airport for years for my sleds.
Exactly how hot do you think several gallons of below-freezing fuel with constant cooling is getting from a 100 F heat exchanger that's also using the entire tunnel as a heat sink? I bet the fuel in your car on a spring day is warmer.heating the gas via top of heat exchanger is another problem if you are trying to extract every pony you can get I paid for them I’d like to use them.
4 stroke vs 2 and turbo why do we use ice to cool the fuel in a 9 second 1/4 mile car. As I have said in the past if anyone had tunned a big bore or turbo 2 stroke with a carb for max performance would know this is a bad ideaExactly how hot do you think several gallons of below-freezing fuel with constant cooling is getting from a 100 F heat exchanger that's also using the entire tunnel as a heat sink? I bet the fuel in your car on a spring day is warmer.
