Don't always believe what you read or see on the internet.
I will leave this post as good info, but I am still up in the air about actual testing of the stator and telling if it is good or bad. I posted an update below, Thunder
Ok update.
I did some reading and a few youtube training videos. lol
Here is what I found out. If you check a stator no matter what temperature it is if any of the coils ohm out higher than the MAX range it is about 99.9% chance of being bad, They give you a 10-20% range on the ohms, but again my understanding if it is even a tenth over max range its' bad.
So on a twisted turbo kit you unplug the factory fuel pump connection and use that power supply to run the attitude box and the AEM gauge. So when looking at the coil for the fuel pump it ohms out good and it should.
Then on a twisted kit we use the accessory plug to power the hi output fuel pump with the capacitor and rectifier.
So I did some testing on the Charge coils in the stator.
The range for the charge coil is 7.2-10.8 ohms.
At 46f they both ohmed out at 10.4 (within in spec)
At 50f they both ohmed at 10.7 (still within spec)
I put a heat lamp on the stator and warmed it up.
At 100f both charge coils ohmed at 12.1 (way over Max)
So I think a new stator will do the trick and get me going again.
I will try and put together a quick video on how I checked it just so others know. (I am sure a lot of guys know what the hell they are doing, I had to figure it out the hard way)
When the new stator hits my door, I will set them side by side and ohm them out to compare.
When I get the new parts and get it back together I will do a final update.
Thunder
