Watch the video from Holley. They deminstrate how they work. I Just did this upgrade and had a completely empty fuel tank. Added about 1 gallon of gas and primed the fuel system with a battery and the sled started up and ran no problem.
https://www.youtube.com/watch?v=yfE1v65fNZI
Anyone done this on a ‘13-‘15? On these, is that a pressure sensor on the return line near the first pickup?? Kinda looks like a regulator but has a wire going to it and it’s in the return so can’t be a regulator. I’m assuming you’re leaving that on the return and removing everything after it?
Not sure if it matters but looks like the ‘11-‘12 are the same except for this mystery part.
That’s the FPR. Your correct on removing everything after it.
How do you replace the fuel sock?Gregg has over 7,000 miles on his now turboed ‘16 AXYS and it hasn’t been changed. The sock is an easy install.
