Front Track Arm Cracked
goridedoo
3,868
3,546
I see my FTA is about to let go.
Anyone ever see this? Should it be warrantied?
I’d like to have it back together ASAP, thinking about ordering and replacing myself- $232.
2019 850
8224B081-1648-4602-AAF9-593C6CCD192B.jpeg A8361C45-C214-4976-9B0E-249AF88C94A0.png
d8grandpa
906
1,076
93
Alberta
This just happened to my buddy’s sled. It’s a 2017-163. I am waiting for him to take it out and will have a look at it to decide if I can re weld or get new.
Reg2view
2,392
1,601
Check the cross shafts for wear when you pull it - good time to replace them while it's out if needed.
goridedoo
3,868
3,546
Also sounds like something Polaris should address in 2022.
goridedoo
3,868
3,546
So the cross shafts and “arm tubes” that mount both the front and rear arms to the tunnel are bowed. Is this normal?
I wouldn’t think so beings the cross shaft pivots within the arm tube.
BeartoothBaron
1,250
1,333
Roberts, MT
Saw that on an old sled I parted out, and to a lessor degree on one of the torque arms on my old sled – I'd guess it's pretty common on sleds that have seen several seasons, but shouldn't crop up this soon under normal riding. Abuse (like jumping), blown or too soft shocks, or springs that are too soft and/or too lightly preloaded are the causes I can think of. The cracking on the lower cross-shaft seems to me like either the product of poor quality or poor design – I'd brace it like sheetmetalfab did – but also consider a stiffer suspension setup. If you just patch it up and run it for a few rides it shouldn't be a big deal, but in the long run I'd be concerned about binding and abnormal wear. It could also eventually break the inner shaft. Ultimately, it might not be necessary for every rider, but some simple triangle bracing top and bottom would eliminate most of these issues.
A
817
Elko, NV.
I had one snap on an '18 800, it broke at about 65 MPH smokin through some small whoops on the trail. When the arm broke it went straight up through the track, tunnel, gas tank, then wadded the track up in front of the drivers bending the driveshaft and cracking the bulkhead, it also put a bulge in the tunnel, totaled the sled. I had another break last spring, but caught it before it created major damage. The arm needs an update, very weak.
