Okay, help me out here. I'm trying to understand the info's in this thread.
My 2009 153" M8 seems to trench quite a bit. Am I to understand then that less preload in the front spring of the skid is going to alleviate this somewhat? I've currently got 135psi in the rear float and (if I recall correctly) 55psi in each ski float.
Thing is, I'm probably aboot 280-290lbs in all my gear. On a rough trail, I don't think the back of the skid is bottoming out, but it almost felt like the front was (might have just been the square edged de-act's I was hitting though too.) The roughest trails are getting groomed finally though so it should be less of an issue there.
How many turns on that front skid spring will it take for me to notice a difference? I loosened it off about one and half turns tonight. Won't be able to try it though until next weekend at the earliest (hopefully).
Another thing, what effect would I expect shortening the limiter strap a notch and leaving the preload in the spring tight? I would think the idea here is to keep the front of the skid up so as to keep a good shallow approach angle, right? Or is that going to cause a bunch of other problems?
