...no anti-stab kitAre you running an ati stab kit??
I like the valveing changes done to the '09,s and will not move the rear sissor ( although I tried already, LOL).
As for the '08,s stock, (not revalved, didn't know Holtz had played with one yet?). I didn't have the trenching issues some have said they had but I also run with a dual spring set-up (85lb per in. initial start rate) on the middle shock. As I said before, I THINK THIS IS VERY IMPORTANT IN POWDER TO STOP TRENCHING.
What about adding a float for the middle shock?
I am 245 in gear and I had my rear shock at 140 lbs and when i stand on the sled it drops 4-5 inches in the rear right off the bat?? Is this normal feels really soft to me. Any thoughts
two things. it should have about 3.5" of sag with you sitting on it (no bouncing) at the rear skid bolt. also make sure you pump the skid shock with NO weight on it, otherwise it will read artificually HIGH - same with the fronts.
I too am having the same issue. 6 to 8 inches of drop and slow rebound. I am 225 with gear and mine is at 150 psi now. What is the most anyone has ran in these, and what is the solution.
