If it is leaking, that cylinder should be full of fuel. If he tried putting new plugs in before he tried starting it and it still fouled then it would be obvious that it is not the carbon build up on the plugs.Most likely the fuel injector is leaking down. Needs new injectors. Flash alone unlikely to resolve issue. Plug type unrelated.
No plug fouling on mine or buddies 850's. Had 2 plugs physically break though..weird. But always do not touch throttle till 100-110f during warmup, even after a quick snack. My Poo(1st one) was a great sled, wish Poo had a SHOT start system.
Been doing almost this very thing since 2011 with my first PRO. Never fouled a plug one until I started having issues with my 20 850. Had to unplug the fuel pump trick when putting it away. Later figured out that the map was a bootleg one from SLP and not the correct one for the twins on it.Per Indy specialty starting procedure
Start sled
Let idle to 100 degrees
Do not hit the gas at all
Turn off sled
Let sled sit min 5 minutes to heat soak
The motor and get all aluminum up to
Equal temperature
Restart sled
Let temp hit 100 degrees and take off
This is a cold start procedure
1st start of the day
I do this religiously every day and never
Had any problems
It’s sometimes a pita waiting
Just my 2 cents worth
I just picked up a 21 Khaos with a brand new dealer installed top end. Same thing. Did a break in road ride where I was really gentle on it. Wondered if I would foul the plugs. When I went to load the sled out of the garage and onto the deck the next ride it ran like ****. Sounded like it was running on one cylinder. Changed the plugs and ran great the rest of the day. Went to unload it and ran terrible wouldn’t go into reverse. Got it off the deck and ran it up and down a friends driveway and it seamed to clean up.I fouled 3 spark plugs on cold start ups in the mourning as soon as i pull on the dam cord this year. I have a 2019 Rmk 850 with almost 100h on it with the 2019 reflash, i do not get the random bog anymore, but i still foul plugs like crazy, 6 plugs already this year and i have only been out 5 times. While i'm riding it will bog just before the spark plug is completely fouled (like if it's getting to much fuel on one cylinder or something). If anybody has or had these symtomes please let me know if you have found a solution.
P.S. I ride between 1000-3000ft in elevation
