regular maintenance will prevent this from happening.....i bet good money this belt was showing thread for awhile
This is a fact
Belts don't generaly explode or break unless they've been worn badly, if you break a belt in properly and inspect it before each trip it won't happen. Anyone that breaks a new belt has a reason for it happening. So if you neglect your sled then don't drills holes in it or remove belt covers. I personaly don't run a cover and haven't for over 4500 miles, no blown belts. Replace belt every year regardless, running about 1000-1500 mountain miles a year.Now this isn't good advice for those that don't have the knowledge to properly inspect a belt. The same with clutches exploding if its maintained properly it'll stay together, all these stories I'm sure are a result of poor sled maintenance, or leaving a burnt belt from a bad stuck on a sled.
Now I can't wait to see the nay-sayers shouting about this, its just what I do and several others do that ride sleds pretty hard.
keeping powder and water off is the job of your hood.
that belt came off with so much force it would have taken your chin and pushed it through the vent on the back of your helmet.
you snap someone with a towel as hard as you can....it might leave a welt. now, how hard does a 20gram piece of belt have to hit a riveted and reinforced piece of 1/8" aluminum to bend it up like a pop can?.....I will answer that for you..............reallllllllllly hard.
the belt was less then 200 miles old and in good shape. I R&Red my secondary and cheaped out by not taking the time to measure it afterwards.....I just replaced the shims and took off. obviously something moved.
This is a fact
