I have a Floe, and I would not buy another one.
If you get a floe, you might as well try to get them to throw in a torch.
That is what you will need to get the track thawed out enough to get your hold-down into the grooves. Ask anyone that has had a Floe, an they will tell you the same thing.
Another really annoying this about this trailer is the tilt mechanism. On mine (Which is about 8-10 years old), the mechanism that holds the trailer from tilting, gets frozen on from the road spray. AGAIn, you need a torch to thaw it out before you can get it to move.
I would either get a Triton or a SledBed...........
X Rated:
I have a reason to support Floe and it is not the trailer.
Wayne Floe owns a piece of Pier 65, I frequent that place quite often.
that is how I will be supporting thew Floes as apposed to buying the center track open 2 place.
I keep my 2 place out in the open, so it snows all over it. When I go and shovel it off to put my sled on there, I need about 10 minutes with a torch to get the groove open enough to put the tie down into it.
Unless they have changed the design of how the tilt mechanism is held down, the design sucks and should be changed to how Triton and Sled Bed does it.....
Now don't get me wrong, Floe makes some extremely good docks, I have aboutr 70 feet of dock at the cabin with their name on it and the dent in my check book to prove it. I am up at Sandy Lake all the time, and stop in at Fishermans, and Hillcrest and Red Rock, but they need to do some redisgning if they have not already.......
I had a Triton XT 10' tilt deck with the aluminum shell. The trailer main frame cracked behind the rear axle.
I now have a Triton Elite 12' (square nose, tilt) with the Fast Enterprises fiberglass shell. The frame is heavier under the elite and the visibility with tilted in sidewalls is far superior. I am very happy with the entire unit.
