Your spot on for timing, another fresh dump of 8 inches last night makes around 80 inches on the ground.
Get a Map from BearClaw with the 'play areas', also get the real map from the exon station. Also, rent a Snobunje from Bob. Ask for a small tutorial on how to use it, I would recommend the sled to sled. Also Bob rents beacons, probes, pack and shovels if you need and you will. Don't forget to pack the camera and post some pic's up here.
With all the new snow in the mountains EVERYONE remember to check
Avalanche.org for the most up to date reports on riding areas in the west.
Today's Report for Cooke and Bozeman Area.........
Daily snowfall has blanketed southwest Montana over the last 20 days. Winds have been strong, gusty and created wind drifts, most notably at the higher elevation ridge lines where avalanches are likely to be trigger these wind-loading on Buck Ridge south of Big Sky as well.
Talking to snowmobilers yesterday I condensed the entire advisory into one sentence: Besides stability is pretty good. This assessment seems accurate for our entire area. I do not expect folks to snowpit). We’ve gotten similar results in the Madison, Gallatin and Bridger Ranges, but only on a handful of slopes. With the latest round of storms we have not seen natural or human trigger a wind-loaded slopes and skied lines that were not very exposed. step down to deeper layers on select, but not easily identifiable slopes. Dig and test. For today, the avalanche danger continues to be rated wind-loaded terrain. All other slopes have a MODERATE danger
