Are you running a 15 wide track stonehands?
trinity have you riden it with any xps with the pmax how does it compare you said you lost some float how much allways wonderd if the doos float so good because track or sled balance its cool to be able to compare 15 vs 16
What's the scoop with the Holz 860? Yours-RK-Split Seconds-Terra Alps, or is it straight Holz? I would have looked your direction if I had heard about the 860. BIG JOHN is a super good dude to deal with. I bought his clutch kit, secondary brace, billet adjuster, and a shockwave adjustable helix as well. A little tuning only takes about 1 minute. 8150 rpm has never been so easy to obtain These 3 sleds together would make for quite a test, eh? My SHR860-Camo extreme 15 wide-your Holz860-Poo 5.1 15 wide-and Madmax's RKT860 with a Power claw. What length claw you running Max?
powdermax 154 weighs 53lb
I'm gonna try to get the new 5.1 on a scale. Curious to see how much less the new single ply weighs. Also how well it holds up. I suspect it will hold up ok since I don't ride unless theres good snow.
trinity, how much was your CE new?
And do you jump at all?
Is the 156 to big for bigger jumps?
40-60 footers?
