It works with BMP tune…have been looking into this agent 3. would be nice to relearn valves but not $600 nice. would be nice to prime oil pump. change gears for speedo. someone said it doesnt work if u have a bikeman tune on ecu
You can also use it on your pickup, and much more.have been looking into this agent 3. would be nice to relearn valves but not $600 nice. would be nice to prime oil pump. change gears for speedo. someone said it doesnt work if u have a bikeman tune on ecu
Have you tried calling them?I tried it on my car, isn’t working. And EZ Lynk does not respond to emails is my major complaint!
What can you do on the automotive side with EzLynk? From my research, you need to be a licensed tuner to access the editor software (as opposed to platforms like HPTuners, etc. where users can edit tables). Is this true? I suppose it would still be valuable as a diagnostic scan tool to read codes, etc.You can also use it on your pickup
Good news, I just received a firmware update that says it supports Polaris oil pump priming. Maybe they read this thread I’m going to try it out this weekend. I believe I’ll need to make a power up harness because theirs does not appear to provide DC power to the pump circuit.Does Auto Agent 3 support oil pump priming as a user feature? Contrary to what EzLynk told me through email, you can't use EzLynk to prime the oil pump on the 850 (at least it does not appear to be supported on my app for the Axys with Auto Agent 2 - earlier posts on this thread also say it's not supported for the Matryx). The EzLynk power-up cable doesn't even power any of the pumps (it only powers the ECU).
It works on my 850! I made a simple power up harness and successfully ran the EzLynk oil pump prime. I was a little upset that they told me it had this feature before it was released, but good on them for adding it now!Good news, I just received a firmware update that says it supports Polaris oil pump priming. Maybe they read this thread I’m going to try it out this weekend. I believe I’ll need to make a power up harness because theirs does not appear to provide DC power to the pump circuit.
You can read and clear most diagnostic codes on your Duramax. Depending on the issue it might not take it out of limp mode. If there is a hardware issue on the truck it will immediately trigger the code again after you clear it. That issue will have to be resolved separately.Can it read and clear codes on a 2019 gmc duramax? If the truck goes into limp due to def issues can you clear it to take it out of limp?
you have a pic of the screen with oil prime option?It works on my 850! I made a simple power up harness and successfully ran the EzLynk oil pump prime. I was a little upset that they told me it had this feature before it was released, but good on them for adding it now!
Yes, there are no added fees to use the special functions for each machine or vehiclecan you buy this and only use for valves and pump priming? or do u have to get a license or user fees etc. i dont care about the tunes
I took a screenshot. You need to update the firmware to add this feature.you have a pic of the screen with oil prime option?
No, and unfortunately it doesn’t look like the EzLynk power up harness will power the pump.Cool. Does the included power plug power up the oil pump though?
An updated version is in the worksi wonder if they have a updated the power adaptor
imagine thatAn updated version is in the works
