yanush New member Premium Member Jan 14, 2010 #1 What is the max exausht temperature I just installed a dual koso egt gauge on my sled and was wandering at witch temp the piston would melt thanks
F-Bomb SnoWest Paid Sponsor Premium Member Jan 14, 2010 #2 doesn't work like that....go to www.f-bombracing.com and read up on digatron tech page. That should give you the basics of what you need to know.
S sodfarmer Member Jan 14, 2010 #3 If you are you putting your gauge on a sled that you know runs safely now then the note your temps and anything significantly hotter you should worry about. If you are running an unknown setup then following Rob's tech page is the way to go. Good luck.
