Gman.... how does an EVOL resist bottoming better than say a Float2 or spring shock?
The compression ratio of an air spring system compares the starting air volume of the air spring (at full extension) to the ending air volume (shock at full bottom-out). This ratio between the two volumes determines the progressiveness at which the air spring builds the slope of the spring curve.
The Walker Evans suck no matter how much damping you do, they will still bottom with those pathetic stock springs! In fact I've hear both Raptor and Z Bros have come up with dual rate replacements for the lame stock springs on the Pro and they work quite well from what I'm told.
Gman... not baiting you at all.
EVOL's are less progressive than a Float2 though... Unless you crank up the EVOL chamber pressure higher than the main when the shock is fully compressed... that would effectively "lock out" the IFP in the EVOL chamber and defeat the purpose ... Which is to allow you to run higher initial spring force (main air pressure) without the end of travel ramp-up of the pressure that can make them harsh.
I had a good talk with Tom Dynes at his shop about this very topic a couple of weeks back.
EVOL Cutaway
From FoxRacingShox website:
The EVOL chamber allows this volume to be variable as the shock compresses.
I believe that the EVOL R's and X's will be running a jounce bumper next season... The Elka shocks above... EXIT's Raptors etc.. have jounce bumpers as well... that really ramps up the spring rate at the end of travel...
The 2013 PRO RMK's have the same shocks with a minor change in the valving... but they also run a jounce bumper on them... the 2011's and 2012's did not.... which I think is a small detail that can make them more bottom resistant... and something that is cheap and easy to add to the shock. (one of the least expensive in fact).
Those EVOL R's ARE excellent shocks... with a lot of technology in them... wait another season and you'll see even more evolution of the same shock.
If you like mogul bashing as much as you talk about...you should try a X model with the DSC feature!
Glad you finally got her dialed in the way you need it.
Ride hard my friend!!
MH what you are saying is confusing. ALL the set up data that I got from Tom shows main pressure quite a bit lower than Evol pressure. For an Evol R used on an XP for my son's weight he said start with 60lbs in the main and 90 in the Evol. We backed off the main a few pounds so far and they work good. It is my under standing that the main pressure builds up as the shock is compressed then peaks and transitions to the EVOL chamber to prevent bottom out. I am using Tom's Evol Rs on my Freeride and like them a ton better than stock. Tom's service is pretty spectacular too. I have some more set up to do and will be posting a full report. Very happy with the purchase so far.
Mountainhorse:Unless you crank up the EVOL chamber pressure higher than the main when the shock is fully compressed.
