I think the all electric bikes are the way to go. Another 10 years and it might be feasible. I think it would be so weird to be boon docking through the trees and not make any noise!!! haha
As crazy as some people may think it sounds... I think you're right on track with the "boon docking through the trees and not make any noise" idea.
Coming from a skiing and snowboarding background, there used to be nothing better than flying through the fresh snow when all you can hear is yourself breathing and your friends around you having fun!
With all of the crazy rich treehuggers trying to close Our Forests to motorized recreation, We need to find a solution to being quiet if we want to stay.
No traction for the Hydrostatic Kubota snowbike I am disappointed. No need for brakes do it hydrostatical just 2 hoses going from the engine to the drivaxle with the drive motor right on it. the engine could be located anywhere on the bike not being limited by chain or belt drives.
I guess no love for tractors on this forum come on guys lets hear it for the kubota snowbike
Just because you want and think something should happen, it does not follow that it will happen. Electric snow bike limitations are caused by the battery capacity and extra weight, not tree huggers' disdain. Our sport does not cause as much forest use conflict in the winter as it does in the summer. Just try to be as quiet as possible all year long. And you guys who ride those intentionally loud set ups (you know who you are) - you're not kids anymore, time to grow up. Less sound = more ground!!
Too much loss from fluid power would be my guess. Any fluid system generally has large cooling systems, big cooling means lot of hp wasted. Anything that changes power in forms loses some. Change direction of power like a shaft drive, power loss. That’s why chain drive is more efficient than shaft. Even an Oring chain takes a few hp compared to belt, just from the friction of those tiny o rings. So fun factor and weight means minimizing losses.
interesting idea about going hydraulic, there was a 2 wheel drive yamaha wr450 a few years back that used a hydraulic hub for the front drive.
A dead give away of poor efficiency is anything that gets hot is not efficient.
Belt cvt will get hot enough to burn you, a hydraulic pump, generator and electic motor, etc wasting hp to make heat.
For a while now i've been running one plain chain and one o-ring chain at the same time to see which wears out faster. So far they are stretching equally but I notice the o-ring chain gets almost hot enough to burn on the road and the regular one is cold......
Perhaps one day, when we are all gone (200+ years), the "intelligent" machines we leave behind will be riding around in the snow with unlimited range, once they figure out the small-package fusion reactor.
